Oils may be overlooked when looking for the “apparent trigger foods” in the IC diet In the energy science approach there are specific oils that carry the hot quality and these in the end will aggravate the small bowel, the seat of Pitta energy which is as you recall the energy of transformation in the body These oils if used improperly can produce the bladder pain of the IC bladder pain syndrome
Why would the small bowel be the focal point of transformative energy? It’s in the small bowel that foods are literally transformed from a vegetable, say broccoli…. and that piece of broccoli is transformed into molecules that can be used by your body for repair or energy to do things So when oils heat the small bowel they increase the energy pattern of Pitta which is responsible for the burning on urination as well as the pelvic burning that is associated with IC, chronic prostatitis, fibromyalgia, and vulvodynia IBS is also associated with diarrhea due to the hot quality in the small bowel The heat of GERD happens in the stomach
Oils That Heat the Small Bowel
Almonds are actually seeds and in the skin of the almond are numerous enzymes that produce transformation so the almond can reproduce itself into another tree If the skin of the almond is left in place during the production of the oil then the oil will be heating The same is true for almond butter
Apricot, corn, mustard, safflower, and sesame round the list of oils to avoid
So you should think twice about fried foods in restaurants since you have no control over what kinds of oils are used
Cooling Oils
You may remember that castor oil is heating internally but when applied to the skin it has a cooling effect This particular fact can be utilized as a treatment effect in terms of utility in the management of IC flares as I’ve written earlier
Coconut and avocado oils can be used like castor externally due to their cooling effect but unlike castor they also have too much of a cooling effect internally so should not be used in cooking Hence routine use of coconut oil internally, even though the rage from a matter science view currently, is not a good idea as it will disrupt agni which is extremely important for health and improving your chances of healing IC
Sunflower, ghee, canola, olive, soy, flaxseed, primrose, and walnut are most suitable in descending order….so sunflower is the most cooling and walnut the most heating even though it has a cooling effect to the small bowel
So armed with this information you can begin to make better energetic choices around the choice of cooking oils in the kitchen
A Word About Ghee
Ghee or clarified butter is an excellent cooking oil(high burn point) because not only does it cool the small bowel but its qualities are those of our digestive fire
Said another way, many who have IC have poor agni, ie poor digestive strength Using ghee on a regular basis helps promote strong digestion and in an indirect way begins healing IC
Anyone with IC should use ghee on a regular basis In our next post together we’ll discuss how to make this amazing cooking oil
