The pain of interstitial cystitis(IC) is chronic, intermittent, and eventually debilitating It is pelvic in origin and often originates from the bladder but may also involve the vagina leading to painful intercourse(dyspareunia) The pain distribution is from belly button to midthigh and is associated with episodic urinary burning, urgency, and frequency
Diagnosis of the Disease Label of IC
This complex of symptoms is labeled by the current matter or molecular science healing discipline(your urologist) by many different names: chronic pelvic pain syndrome(CPPS), painful bladder syndrome(PBS), vulvodynia(vaginal pain), chronic prostatitis, and of course interstitial cystitis Fibromyalgia, depression, and chronic fatigue syndrome can be added to this list of synonyms as a frequent diagnoses often associated with IC Read on to see why
The diagnosis of IC is based on a negative urological evaluation of the urinary tract which includes:
History and physical
Most often negative urine cultures(of many negative cultures there may be some positive)
Normal urine cytology
Normal CTscan(xray evaluation of the urinary system)
Often a normal cystoscopic exam of the bladder(looking in the bladder) except there is pain with bladder filling during the exam
What is IC?
The current matter or molecular science understanding of IC is that the protective internal layer of the bladder(called the GAG layer) becomes damaged by unknown substances in the urine It is unclear to the matter science discipline why fibromyalgia is associated with IC
The energy science understanding of IC pain is that it is an imbalance of qualities Two basic vibrational frequencies among others become disturbed in the gastrointestinal tract(GIT) leading to increased the increased hot and mobile qualities
This imbalance of the hot quality leads to the burning pain in the bladder, pelvic region, and thighs Hence not only bladder symptoms occur but also vaginal pain as well leading to painful sexual intercourse also referred to as vulvodynia Fibromyalgia occurs due to these qualities among others involving the liver Chronic fatigue syndrome and depression occur due to the imbalance of qualities already manifesting as IC Sooo… the imbalance of the qualities lead to a group of labels used in the matter science model of healing
The increased mobile quality in the bladder leads to urinary urgency and frequency which are the hallmarks of the pain syndrome
But you can begin to see how the energy science model in its simplicity helps you understand how all dis-eases can be simplified as opposed to the current matter science where there is such confusion
Gastrointestinal Tract(GIT) Origin
In contrast to the matter or molecular science theory of disease, the energy science view is that the GIT is the origin of all dis-eases that occur in the energy mindbody including IC
This explains why nutrition and change in the type of foods ingested is important in dealing with not only IC pain but dis-eases in general that are painful The GIT imbalances increase the qualities that eventually lead to the symptoms in the pelvic region Witness the association of acid indigestion and irritable bowel syndrome(IBS) with IC
Why is the bladder or pelvic region selected rather than the lungs or brain or muscular system? The energy science of Ayurveda describes that there are weaknesses in the mindbody that predispose the organ or area to be affected
Three Things To Do Right Now
Since the GIT is the origin of IC it makes sense to eliminate those foods that are producing the imbalance You have two options Either go to icdiet.com or go to foodsheal.com and select the appropriate nutritional format
Look at the food incompatibility list
If you have had longstanding chronic symptoms you probably need more attention to your imbalances In this case sign up for a free consultation with me to explore what can be done to help you with your dis-ease
Or right now you can sign up by putting in your email in the right hand column box on the page You’ll also get a free report on healing IC and become part of our growing IC community interested in dealing with chronic dis-ease in a different more effective way
Until next time Ciao To Health as a Skill Love DrBill
PS Our ic-solutions.tv Facebook page is up Would you stop by and if so inclined like it
PSS If you know a friend who could benefit from this explanation of IC could you pass it along thanks DB
